3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 21 9/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 18 1/4" wide x 11 7/16" high (464 mm x 290 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M PF21.6W - display privacy filter - 21.6" wide
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 21.6" wide
- 1 year warranty
- Product Type
- 21.6" wide
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
9ZBM 037868 Condition: Customer return - item has been used and shows signs of use |
£10.42 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
