3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 18 1/2" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 16 1/16" wide x 9 1/16" high (409 mm x 231 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M PF18.4W9 - notebook privacy filter
- Product Type
- Notebook privacy filter
- 40.8 cm 23 cm
- Display Screen Size Compatibility
- 18.4" wide
- 1 year warranty
- Product Type
- 40.8 cm
- 23 cm
- 18.4" wide
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
