3M 17.1" TFT Privacy Screen
Quicklinx: 7W99WS00 Mfr#: PF17.0W
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen laptops or desktop monitors with a diagonally measured 17 1/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 14 1/2" wide x 9 1/16" high (368 mm x 230 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
3M Notebook/LCD Privacy Computer Filter PF17.0W - security screen filter - 17"
Security screen filter
Display Screen Size Compatibility
17"
17"
