3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen laptops with a diagonally measured 16 1/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 13 15/16" wide x 7 7/8" high (355 mm x 201 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
- 3M PF16.0W9 - notebook privacy filter
- Product Type
- Notebook privacy filter
- 35.5 cm 20 cm
- Display Screen Size Compatibility
- 16" wide
- 1 year warranty
- Product Type
- 35.5 cm
- 20 cm
- 16" wide
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
