3M Gold Privacy Filters keep confidential information private when working in public places. User sees clearly while people on either side see a vivid golden screen. Designed to fit widescreen laptops with a diagonally measured 14 1/8" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 11 15/16" wide x 7 1/2" high (304 mm x 190 mm). Includes your choice of two easy-to-use attachment methods. Offers the highest level of clarity within 3M's line of privacy filters. Reversible, privacy filter can be used with either gold or black side facing the user. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
Privacy you can't ignore
State-of-the-art gloss surface with a vibrant golden screen dazzles onlookers while defending data. -
See the light
Now experience even brighter and sharper text and images without blurring or distortion. -
Fort Knox for your laptop
Precision-fitted filters shield data from curious glances and screens from scuffs and scratches. -
Enlightened ease
Simple to attach and remove, they stay in place when the laptop is closed so you never lose sight of them.
- 3M GOLD Privacy Filter - notebook privacy filter
- Product Type
- Notebook privacy filter
- 30.5 cm 19.1 cm
- Display Screen Size Compatibility
- 14.1" wide
- 1 year warranty
- Product Type
- 30.5 cm
- 19.1 cm
- 14.1" wide
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
