3M 14" Laptop Anti-Glare Filter - Frameless
Quicklinx: 9Z90WS00 Mfr#: AG14.0W9
Discontinued, only used stock available
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen laptops with a diagonally measured 14" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 12 3/16" wide x 6 7/8" high (310 mm x 175 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG14.0W9 - display screen filter - 14" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
14" wide
1 year warranty
Package Content
Cleaning cloth
14" wide
Clear
Monitor Filter
Viewing Area Height
17.5 cm
Viewing Area Width
31 cm
Aspect Ratio
16:9
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
