Product
Brand
3M 13" Widescreen (16:10) Laptop Privacy Filter for MacBook Pro
Quicklinx: 9Z9KWS00 Mfr#: PFMP13
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Custom fit to your Apple MacBook Pro 13-inch. The filter application system features an optically clear adhesive designed specifically for display screens. Testing proves that, when kept clean, the filter can be repositioned hundreds of times. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Includes a convenient storage folder that keeps your privacy filter clean while not in use on your device. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
3M Privacy Filter Mac Confidential PFMP13 - notebook privacy filter
Notebook privacy filter
Display Screen Size Compatibility
13"
Dust resistant, self-adhesive backing, dirt resistant
Apple MacBook Pro (13.3 in)
13"
