Product
Brand
3M 11.6" Widescreen (16:9) Netbook Privacy Filter - Frameless
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 9Z94WS00 Mfr#: PF11.6W9
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen laptops with a diagonally measured 11 5/8" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 10 1/8" wide x 5 11/16" high (257 mm x 145 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
3M PF11.6W9 - notebook privacy filter
Notebook privacy filter
25.7 cm 14.5 cm
Display Screen Size Compatibility
11.6" wide
1 year warranty
25.7 cm
14.5 cm
11.6" wide
1 year warranty
Service & Support Details
Limited warranty - 1 year
