Superior 3D Navigation: intuitively and precisely navigate digital models or viewports in 3D space with 3Dconnexion six-degrees-of-freedom (6DoF) sensor technology.
Superior 3D navigation
However you work in 3D, a standard mouse and keyboard just can't get close to the intuitive control delivered by SpaceMouse wireless. This sleek, compact and easy to use 3D mouse lets you position the model or viewport, while you select, create and edit with the standard mouse. -
Wireless freedom
For the first time, 3Dconnexion's 6-degrees-of-freedom sensor is combined with 3Dconnexion 2.4 GHz wireless technology and a rechargeable battery to deliver the reliability of a wired device, without the clutter of cords. Connecting SpaceMouse wireless couldn't be easier. Simply pop the micro-USB receiver in your PC or Mac and leave it there, while you enjoy a real-time connection to your 3D content. -
Flexible recharging
You'll never have to cope without SpaceMouse wireless thanks to its impressively long battery life of up to one month and corded or un-corded operation. When it does need some juice the supplied micro-USB cable handles re-charging and data at the same time. Just connect and continue working. -
Stylish design
Everything about SpaceMouse wireless says attention to detail, from its small footprint and brushed steel base to its two conveniently positioned buttons. -
Easy to use
Each SpaceMouse wireless button opens its own radial menu providing convenient mouse-click access to four application commands.
- 3Dconnexion SpaceMouse Wireless - 3D mouse - 2.4 GHz
- 3D mouse
- Connectivity Technology
- Wireless, wired - 2.4 GHz
- 7.8 cm x 7.8 cm x 5.4 cm
- 424 g
- Wireless Receiver
- USB wireless receiver
- Buttons Qty
- 2
- 3D sensor cap, battery indicator, six-degrees-of-freedom (6DoF) technology, radial menu button
- Cables Included
- 1 x USB cable
- Battery
- 1
- OS Required
- Linux, Apple MacOS X, Microsoft Windows
- 2 years warranty
- 3D mouse
- Wireless Receiver
- 7.8 cm
- 7.8 cm
- 5.4 cm
- 424 g
Input Device
- Wireless, wired
- Interface
- 2.4 GHz
- Buttons Qty
- 2
- Cables Included
- 1 x USB cable
- TUV, BSMI, cUL, WHQL, FCC Part 15 B, KCC, WEEE
- Technology
- Lithium polymer
- Installed Qty
- 1
- Run Time (Up To)
- 1 month
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.87 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.51 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £12.76 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £19.32 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £16.73 |
C2G USB Superbooster Extender Kit | In Stock | £37.81 |
C2G Trulink® USB to Gigabit Ethernet Adapter | In Stock | £23.38 |
C2G USB to HDMI Adapter with Audio Up To 1080p | In Stock | £42.30 |
