Product
3Dconnexion SpaceMouse Wireless 3DX-70043
Quicklinx: B9MRWS00 Mfr#: 3DX-700043
Superior 3D Navigation: intuitively and precisely navigate digital models or viewports in 3D space with 3Dconnexion six-degrees-of-freedom (6DoF) sensor technology.
  • Superior 3D navigation
    However you work in 3D, a standard mouse and keyboard just can't get close to the intuitive control delivered by SpaceMouse wireless. This sleek, compact and easy to use 3D mouse lets you position the model or viewport, while you select, create and edit with the standard mouse.
  • Wireless freedom
    For the first time, 3Dconnexion's 6-degrees-of-freedom sensor is combined with 3Dconnexion 2.4 GHz wireless technology and a rechargeable battery to deliver the reliability of a wired device, without the clutter of cords. Connecting SpaceMouse wireless couldn't be easier. Simply pop the micro-USB receiver in your PC or Mac and leave it there, while you enjoy a real-time connection to your 3D content.
  • Flexible recharging
    You'll never have to cope without SpaceMouse wireless thanks to its impressively long battery life of up to one month and corded or un-corded operation. When it does need some juice the supplied micro-USB cable handles re-charging and data at the same time. Just connect and continue working.
  • Stylish design
    Everything about SpaceMouse wireless says attention to detail, from its small footprint and brushed steel base to its two conveniently positioned buttons.
  • Easy to use
    Each SpaceMouse wireless button opens its own radial menu providing convenient mouse-click access to four application commands.
3Dconnexion SpaceMouse Wireless - 3D mouse - 2.4 GHz
3D mouse
Wireless, wired - 2.4 GHz
7.8 cm x 7.8 cm x 5.4 cm
424 g
Wireless Receiver
USB wireless receiver
Buttons Qty
2
3D sensor cap, battery indicator, six-degrees-of-freedom (6DoF) technology, radial menu button
1 x USB cable
1
Linux, Apple MacOS X, Microsoft Windows
2 years warranty
3D mouse
Wireless Receiver
7.8 cm
7.8 cm
5.4 cm
424 g
Input Device
Wireless, wired
2.4 GHz
Buttons Qty
2
1 x USB cable
TUV, BSMI, cUL, WHQL, FCC Part 15 B, KCC, WEEE
Lithium polymer
Installed Qty
1
Run Time (Up To)
1 month
Software Included
Drivers & Utilities
B9MR C2G 2m USB 2.0 A/B Cable - Black In Stock £3.84
B9MR C2G 5m USB 2.0 A/B Cable - Black In Stock £4.98
B9MR C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
B9MR C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.17
B9MR C2G USB Superbooster Extender Kit In Stock £36.55
B9MR C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.60
B9MR C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
