3Dconnexion SpaceMouse Enterprise 3D Mouse 31 Buttons Wired USB
Quicklinx: CVKSWS00 Mfr#: 3DX-700056
It's easier than ever to view your 3D models with SpaceMouse Enterprise's 6-Degrees-of-Freedom (6DoF) sensor and instant access to Standard and Custom Views. Gentle manipulation of the controller cap translates to smooth and intuitive 3D navigation, while a press of a finger snaps your model to a standard view of your choice. The addition of three Custom View keys makes for an unequaled 3D navigation experience.
  • Real-time understanding of 3D engineering design
    It's easier than ever to view your 3D models with SpaceMouse Enterprise's 6-Degrees-of-Freedom (6DoF) sensor and instant access to Standard and Custom Views. Gentle manipulation of the controller cap translates to smooth and intuitive 3D navigation, while a press of a finger snaps your model to a standard view of your choice. The addition of three Custom View keys - exclusive to SpaceMouse Enterprise - makes for an unequalled 3D navigation experience.
  • Fast and efficient 3D modeling
    It's easier to do what you want to do with 12 of your favorite application commands at your fingertips. And the right tools are always available because SpaceMouse Enterprise's intelligent function keys automatically update as you change applications or environments.
  • Ergonomics
    Your hands are your livelihood. The SpaceMouse Enterprise is built to protect them at all costs from the aches and pains that are increasingly common among hard-working CAD professionals. This powerful but easy-to-use tool provides much requested features, including a complete set of keyboard modifiers, means less hand travel to the keyboard than ever before.
3Dconnexion SpaceMouse Enterprise - 3D mouse - USB
3D mouse
Wired - USB
15.4 cm x 24.9 cm x 5.8 cm
800 g
Buttons Qty
31
Programmable buttons, LCD screen
Cable Length
2 m
Apple MacOS X, Microsoft Windows
4-year warranty with product registration
3D mouse
15.4 cm
24.9 cm
5.8 cm
800 g
Input Device
Wired
USB
Buttons Qty
31
Cable Length
2 m
1 x USB - 4 pin USB Type A
BSMI, FCC, RoHS, WEEE, KC, China RoHS, RCM
Limited warranty - 4 years with product registration
