SpaceNavigator for notebooks is the portable 3D mouse that brings intuitive, precise 3D navigation to mobile users.
It's like reaching in to the screen and holding the model in your hand
Redefine the way you work with 3D applications. Pan, zoom and rotate as if you are holding the model in your hand or fly like a helicopter through three-dimensional worlds. -
Fly like a helicopter
It's a level of control that's simply not possible with a traditional mouse and keyboard. Whether you're crating dazzling 3D models or exploring vitual worlds, SpaceNavigator's superior navigation experience sets your imagination free!
- 3Dconnexion SpaceNavigator for Notebooks - 3D mouse - USB
- 3D mouse
- Connectivity Technology
- Wired - USB
- 6.4 cm x 6.4 cm x 4.3 cm
- 250 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 2
- Handle rotation, programmable buttons
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 SP4, Microsoft Windows Vista, Apple MacOS X 10.4.6 or later, Microsoft Windows Vista (64-bit versions)
- 2-year warranty
- 3D mouse
- 6.4 cm
- 6.4 cm
- 4.3 cm
- 250 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 2
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Carrying case
- Cables Included
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Pentium III HD 140 MB
- Limited warranty - 2 years , Technical support - phone consulting , Product info support - e-mail consulting , Product info support - web support
