Your basket is empty
3D Systems Cube 3D Print Cartridge ABS - Red
Quicklinx: 98VYWS00 Mfr#: 350162
Type: 3D Printing
Technology: [N/A]
£32.22 ex VAT
£38.66 inc VAT
Bring your imagination to life in the colour of your choice with the Cubify ABS 3D Printer Cartridge.
Compatible with 2nd generation Cube 3D printers, this cartridge allows you to use ABS to print your own creations. Now you can let your creativity run wild.
It is simple to install the cartridges thanks to the click-in, click-out system, so you won't have to waste time trying to install it.
The cartridge will detect whether there is enough filament in the cartridge to complete your creation, alerting you to problems before you begin printing.
ABS is s petroleum based plastic. Whilst not entirely flexible, it considered more hard wearing and impact resistant than the more brittle PLA.
3D Systems - red - ABS filament
ABS filament
Printing Technology
FDM
Printing Colour
Red
Compatible with
3D Systems Cube
Consumable
Consumable Type
ABS filament
Printing Technology
FDM
Red
Included Qty
1-pack
Compatible with
3D Systems Cube
Type: 3D Printing
Technology: [N/A]
Brand: 3D Systems
Price Range Ex VAT: 0 - 50
