Bring your imagination to life in the colour of your choice with the Cubify ABS 3D Printer Cartridge.
Compatible with 2nd generation Cube 3D printers, this cartridge allows you to use ABS to print your own creations. Now you can let your creativity run wild.
It is simple to install the cartridges thanks to the click-in, click-out system, so you won't have to waste time trying to install it.
The cartridge will detect whether there is enough filament in the cartridge to complete your creation, alerting you to problems before you begin printing.
ABS is s petroleum based plastic. Whilst not entirely flexible, it considered more hard wearing and impact resistant than the more brittle PLA.
- 3D Systems Cube - green - ABS filament
- Product Type
- ABS filament
- Printing Technology
- FDM
- Printing Colour
- Green
- Compatible with
- 3D Systems Cube
Consumable
- Consumable Type
- ABS filament
- FDM
- Green
- Included Qty
- 1-pack
- Compatible with
- 3D Systems Cube
