3D Systems Cube 3D Print Cartridge  PLA - White
Quicklinx: 99VQWS00 Mfr#: 380146
Bring your imagination to life in the colour of your choice with the Cubify PLA 3D Printer Cartridge.
Compatible with 2nd generation Cube 3D printers, this cartridge allows you to use PLA to print your own creations. Now you can let your creativity run wild.
It is simple to install the cartridges thanks to the click-in, click-out system, so you won't have to waste time trying to install it.
The cartridge will detect whether there is enough filament in the cartridge to complete your creation, alerting you to problems before you begin printing.
3D Systems Cube - white - PLA filament
PLA filament
Printing Technology
FDM
Printing Colour
White
Compatible with
3D Systems Cube
Consumable
Consumable Type
PLA filament
Printing Technology
FDM
White
Included Qty
1-pack
Compatible with
3D Systems Cube
