2-Power Main Battery Pack 7.4V 6600mAh 49Wh
Quicklinx: B64SWS00 Mfr#: CBI1013A
Whether you require a replacement battery, or an additional pack to keep you working, PSA has a power solution to match.
2-Power Main Battery Pack - laptop battery - Li-Ion - 6750 mAh
Laptop battery
312 g
Lithium Ion - 6750 mAh
Battery Form Factor
Internal
Dark grey
2.1 cm x 14.3 cm x 5.8 cm
Panasonic Toughbook CF-18 Tablet PC version
Laptop battery
Battery Enclosure Type
Internal
Dark grey
Lithium Ion
Voltage Provided
7.4 V
6750 mAh
2.1 cm
14.3 cm
5.8 cm
312 g
