2-Power 4GB DDR3L 1600MHz 1Rx8 LV SODIMM
Quicklinx: CD86WS00 Mfr#: MEM5302A
2-Power memory modules are manufactured using high quality DRAM chips made by major brands such as Samsung, Hynix, Micron, Nanya or Elpida. These premium memory modules are compatible with leading brands such as Dell, HP, IBM/Lenovo, Toshiba, Apple and Acer. The extensive range of DIMM and SO-DIMM memory modules are suitable for servers, desktop PCs, laptops, even printers and are supplied with a life-time warranty. Whether you are a reseller, do custom builds or need to respond to detailed RFQs, you can rely on 2-Power memory. The extensive range of DIMMs and SO-DIMMs in terms of capacity, clock speed, fully buffered, un-buffered, load reduced, registered, module configuration, memory technology allow for both high end enterprise applications and consumer applications. We are able to offer fully compatible memory against OEM modules. We are also able to match specific memory to your server, desktop PC or laptop.
2-Power - DDR3 - 4 GB - SO-DIMM 204-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Dual rank, unbuffered
1-year warranty
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
RoHS
1-year warranty
