Read the review on Bit-Tech - Score 86%
Compact Powerline Adapters with Extra Plug Upgrade Your Home Network Conveniently
The ZyXEL PLA4211 500 Mbps Mini Powerline Pass-Thru Ethernet Adapter improves performance for up to 60% comparing to the 200 Mbps powerline technology**. The compact design with extra power outlet gives you the convenience to deploy home networks without the compromises of your existing power outlet. The embedded noise filter of PLA4211 provides more stable multimedia streaming enjoyments by minimizing interference from other home electric devices.
Fast Media Network
ZyXEL PLA4211 500 Mbps Mini Powerline Pass-Thru Ethernet Adapter Starter Kit upgrades home networks with faster wireless speeds of up to 500 Mbps* to provide more stable and reliable connections for web surfing.
Additional Power Outlet
The new, compact ZyXEL PLA4211 gives you the installation flexibility to turn power lines into a home network. You can conveniently deploy the home network and provide power to other electrical devices instantaneously through the extra power outlet. With plug-and-play installation of a pair of PLA4211, you can easily connect your Smart TV, Blu-ray™ players, DVRs, PCs or game consoles to the home network through any electrical outlet.
Ideal for Media Streaming and Gaming
Powered by the IEEE 1901 500 Mbps technology*, the ZyXEL PLA4211 can provide a stable high-performance network for you to enjoy multiple HD streaming, multiplayer gaming and Web surfing simultaneously. The embedded noise filter enables the PLA4211 to suppress noise from all electronic equipment plugged into it and also enhances the network environment for multimedia streaming.
Compact design with an extra power outlet for convenient setup
The compact ZyXEL PLA4211 gives you the installation flexibility to turn power lines into a home network. You can conveniently deploy the home network and provide power to other electrical devices instantaneously through the extra power outlet. With Plug-and-Play installation of a pair of PLA4211, you can easily connect your Smart TV, Blu-ray players, DVRs, PCs or game consoles to the home network through any electrical outlet. -
Enjoy stable HD videos and gaming
Powered by the IEEE 1901 500 Mbps technology, the ZyXEL PLA4211 can provide a stable high-performance network for you to enjoy multiple HD streaming, multiplayer gaming and Web surfing simultaneously. The embedded noise filter enables the PLA4211 to suppress noise from all electronic equipment plugged into it and also enhances the network environment for multimedia streaming. -
QoS enhances media streaming quality
The advanced Quality of Service (QoS) features improves the quality of multimedia streaming applications such as triple-play services by prioritizing HD video streaming, high-speed Internet access and VoIP. -
Green products save energy consumption
When there is no active Ethernet connection, the PLA4211 will enter a power-saving mode that consumes only 0.5 watt to reduce energy consumption by over 88%.
- Zyxel PLA4211 - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV), IEEE 1901
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- 128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS), integrated power socket
- HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 6.4 cm x 3.9 cm x 10.2 cm
- 184 g
- System Requirements
- Microsoft Windows Vista / XP / 7
- Localisation
- United Kingdom
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- HomePlug AV, IEEE 1901, FCC, RoHS, LVD
- Status Indicators
- Power, link/activity
- 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- 4 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 6.4 cm
- 3.9 cm
- 10.2 cm
- 184 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
