Zyxel XGS4528F L3 Managed 10G Stackable Switch
THE SWITCH EXPERT
Quicklinx: 8PDSWS00 Mfr#: 91-010-146005B
Unlike competitors' offering of individual models for GbE copper and fiber connectivity, the leading architecture employed by XGS-4528F delivers 24 1000Base-T copper interfaces along with standard RJ-45 connectors and 24 SFP slots in a 19" 1U enclosure. This unique benefit gives network designers the highest flexibility and cost saving in terms of equipment investment, network administration and system maintenance.
With two high-performance 12G stacking ports on the back panel, over 10 units of XGS-4528F can be easily hard-stacked in a ring architecture; this feature makes XGS-4528F highly scalable and eases the network expansion and administration. Moreover, as the stacking ports come with every XGS-4528F unit, customers have no need to spend extra for stacking modules and stacking cables.
Each XGS-4528F provides 144Gbps-switching capacity for wire-speed performance delivered on all GbE copper/fiber ports within the stack, as well as stacking ports and optional 10G uplinks. In addition, advanced L3 switching, multicasting, resiliency including OSPF, DVMRP, VRRP also help delivering optimal performance to the entire network.
Zyxel XGS-4528F - switch - 24 ports - Managed
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 24 x shared SFP
MAC Address Table Size
8K entries
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, DVMRP, VRRP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2
Flow control, Layer 3 switching, Layer 2 switching, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IP address filtering, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, DHCP server
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
43.8 cm x 31 cm x 4.4 cm
7 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
8K entries
Max Units In A Stack
10
Routing Protocol
Encryption Algorithm
SSL, TLS
Authentication Method
Secure Shell (SSH), TACACS+, Secure Shell v.2 (SSH2)
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x RJ-45 management , 1 x console - 9 pin D-Sub (DB-9) management , 2 x network stack device , 24 x SFP (mini-GBIC)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Internal power supply
FCC, UL 60950-1, IEC 60950-1, EN 60950-1
43.8 cm
31 cm
4.4 cm
7 kg
45 °C
10 - 90%
