Zyxel WRE2205 Wireless N300 Range Extender/Repeater
Quicklinx: 890KWS00 Mfr#: WRE2205-GB0101F
  • IEEE 802.11n
Designed as a user-friendly alternative to complicated, unsightly network extension options, the ZyXEL WRE2205 Wireless N300 Range Extender makes extending the range for an existing 802.11 b/g/n wireless network fast and easy.
Just plug the WRE2205 directly into the power outlet, an LED signal strength indicator will let you know the most ideal installation place at a glance.
One-click Wi-Fi Protected Setup (WPS) setup makes installation frustration-free while a built-in Ethernet port provides instant network access to wired devices.
Easily extend the wireless coverage
Compatible with 802.11 b/g/n wireless networks, the ZyXEL WRE2205 can extend wireless range to cover your network devices throughout the house. You can easily enjoy videos streaming, gaming and Web surfing with tablets, laptops or smart phones anywhere at home, even at otherwise hard-to-reach places.
Convenient placement
The compact wallmount design allows flexible placement to give the best wireless coverage and performance, as well as to eliminate the need for unsightly wires. Additionally, the ZyXEL WRE2205 has been designed with an LED light to indicate the signal strength for optimal Wi-Fi coverage. You can install it at the location with the strongest wireless signal to extend wireless coverage and enjoy the high-speed wireless network right away.
Easy setup
Featuring an easy setup wizard and Wi-Fi Protected Setup (WPS) button, the ZyXEL WRE2205 allows you to set up the extender and connect to the root access point easily and quickly.
Save energy effortlessly
With a power on/off switch, the ZyXEL WRE2205 allows you to easily turn off the device when it's not in use. So you can also do your part to save energy for a more eco-friendly environment.
