The P-661HNU-F1 featuring 802.11n technology provides the ultimate solution for speed and coverage. P-661HNU-F1 provides stable and reliable wireless connections for high speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11 b/g Wi-Fi certified device.
802.11n technology for extreme performance and coverage
The P-661HNU-F1 featuring 802.11n technology provides the ultimate solution for speed and coverage. P-661HNU-F1 provides stable and reliable wireless connections for high speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11 b/g Wi-Fi certified device. -
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code. -
SPI Firewall and IPSec VPN
The Stateful Packet Inspection (SPI) Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on SPI, Denial of Service (DoS) and DDoS features, the P-661HNU-F1 provides the first-line defense against hackers, network intruders and other harmful threats. Besides, P-661HNU-F1 allows companies to establish Virtual Private Network (VPN) connections with business partners, as well as remote and branch offices. VPN uses data encryption and the Internet to provide transparent, secure communications between two or more sites without the expense of leased site-to-site lines. The P-661HNU-F1 provides VPN connection with IPSec technology. -
TR-069 remote management
With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "Plug and Play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers. -
3G WAN backup support
With the built-in USB interface for a 3G dongle, the P-661HNU-F1 can offer you the flexibility to share either a 3G WAN or a xDSL connection with all users in your network when either connection is available without any configuration required.
- Zyxel Prestige 661HNU-F1 - wireless router - DSL modem - 802.11b/g/n - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, READSL
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- Simultaneous NAT sessions: 6000 , Concurrent IPSec VPN tunnels: 2 , IPSec VPN tunnels: 10
- IPSec
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, IGMPv3, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, HTTP, HTTPS, CLI, TR-069
- NAT support, VPN support, DoS attack prevention, packet filtering, ALG support, dynamic DNS server, print server, URL filtering, Access Point operational mode, IPSec Virtual Private Network (VPN), file sharing, event log, Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, 3G USB Dongle Support, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DHCP client
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- 26 cm x 13.5 cm x 4.2 cm
- 400 g
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Capacity
- IPSec
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, CSA, FCC, RoHS, IEC 60950-1, EN 60950-1
- Status Indicators
- Power, WLAN, WAN, LAN, USB, ADSL
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex L
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- 26 cm
- 13.5 cm
- 4.2 cm
- 400 g
- 0 °C
- 40 °C
- 20 - 85% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
