Next-generation Wireless Networking
Are you experiencing slow wireless speeds on your favorite new mobile device? Give it the speed it deserves - upgrade your home network with the ZyXEL NBG6515, AC750 Dual-Band Wireless Gigabit Router. Equipped with the latest 802.11ac technology, the NBG6515 boosts wireless speeds to as high as 750 Mbps on your wireless network.
A dual-band wireless network allows you to create two wireless networks: one 2.4 GHz network for regular Web browsing, news reading, social networking, uploading photos/videos and downloading files, while the other wireless network at 5 GHz allows bandwidth-hogging, timesensitive activities such as HD video streaming or multiplayer online gaming.
Powered by the latest 802.11ac technology
The ZyXEL NBG6515 enables you to utilize the latest wireless technology to achieve faster wireless speeds among the latest wireless mobile devices, which enable smoother HD video streaming, lag-free multiplayer gaming and overall faster wireless online activities.
Powerful, reliable wireless coverage with advanced antennas
Equipped with two external antennas, the ZyXEL NBG6515 provides strong wireless coverage throughout the premises. Enjoy reliable wireless Internet access wherever you are at home.
Gigabit Ethernet ports for fast wired networks
Create a wired network of up to 1000 Mbps taking advantage of the ZyXEL NBG6515’s Gigabit Ethernet ports, which ensures your wired network gets the highest data speed for HD video streaming or faster large data transfers.
Supports for access point and repeater modes
Not only does the ZyXEL NBG6515 share Internet access, it also acts as a dedicated wireless access point to create a wireless network, upgrade the existing one, or extend your existing wireless network with the repeater mode.
Stream and share your digital contents with a USB drive
Connect a USB storage device to the ZyXEL NBG6515 for it to share the stored photos, music and videos throughout your network with its DLNA support. It’s great for the existing set top boxes or video game consoles with DLNA support to create a connected home theater experience.
The ZyXEL NBG6515 enables you to utilize the latest wireless technology to achieve faster wireless speeds among the latest wireless mobile devices, which enable smoother HD video streaming, lag-free multiplayer gaming and overall faster wireless online activities. -
Equipped with two external antennas, the ZyXEL NBG6515 provides strong wireless coverage throughout the premises. Enjoy reliable wireless Internet access wherever you are at home. -
Create a wired network of up to 1000 Mbps taking advantage of the ZyXEL NBG6515's Gigabit Ethernet ports, which ensures your wired network gets the highest data speed for HD video streaming or faster large data transfers. -
Not only does the ZyXEL NBG6515 share Internet access, it also acts as a dedicated wireless access point to create a wireless network, upgrade the existing one, or extend your existing wireless network with the repeater mode. -
Connect a USB storage device to the ZyXEL NBG6515 for it to share the stored photos, music and videos throughout your network with its DLNA support. It's great for the existing set top boxes or video game consoles with DLNA support to create a connected home theater experience.
- Zyxel NBG6515 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 433 Mbps
- DHCP
- Routing Protocol
- Static IP routing
- Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), repeating mode, print server, MAC address filtering, IPv6 support, VPN passthrough, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), DHCP server, UPnP Media Server, reset button, bandwidth control, DLNA Media Server, DHCP client, Denial of Service (DoS)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, IEEE 802.11ac
- 17.5 cm x 11.5 cm x 2.3 cm
- 265.4 g
- Localisation
- Europe
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 433 Mbps
- DHCP
- Routing Protocol
- Static IP routing
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, IEEE 802.11ac, BSMI, IC, FCC, LVD
- Status Indicators
- Power, WAN, LAN, wireless, USB, WPS
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Europe
- 17.5 cm
- 11.5 cm
- 2.3 cm
- 265.4 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
