Your basket is empty
Zyxel GS1510-24 24 port Gigabit Web Managed Switch
Quicklinx: 7BFTWS00 Mfr#: 91-010-236003B
Ports: 24
£94.49 ex VAT
£113.38 inc VAT
The ZyXEL GS1510 series is a user-friendly solution aiming at office network environments demanding silent operation and green technology. The series provides security and Plug-and-Play simplicity for sustainable high-bandwidth connectivity.
The GS1510-24 Switch offers two open Gigabit SFP slots to provide more flexibility on fiber connectivity for long loop reach applications. The GS1510 series not only provides Layer-2 switching capability at wire speed over the current CAT-5 cabling to desktops following the IEEE standards, but also features high performance, ease of use, flexible deployment and enhanced energy efficiency. It is ideal for small businesses to protect the existing network investments while extending managed networks.
ZyXEL GS-1510-24 - switch - 24 ports - Managed - desktop
Switch - 24 ports - Managed
Enclosure Type
Desktop
Ports
24 x 10/100/1000 + 2 x SFP
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 2c, HTTP
Flow control, Layer 2 switching, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3az
AC 120/230 V ( 50/60 Hz )
44 cm x 17 cm x 4.4 cm
2.4 kg
Enclosure Type
Desktop
Ports
16K entries
Routing Protocol
Status Indicators
Port status, link activity, power, system
24 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x SFP (mini-GBIC)
Power supply - internal
20 Watt
44 cm
17 cm
4.4 cm
2.4 kg
RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1
50 °C
10 - 95% (non-condensing)
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
Brand: Zyxel
Price Range Ex VAT: 50 - 100
