Zyxel AMG1202-T10B Wireless N ADSL2+ Router
Quicklinx: 9KPPWS00 Mfr#: AMG1202-T10B-GB01V1F
  • IEEE 802.11n
The ZyXEL AMG1202-T10B Wireless-N ADSL2+ Router features 802.11n technology that provides a solution for ultimate speed and coverage. With data rates of up to 150 Mbps, this ZyXEL AMG1202-T10B provides stable, reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by taking advantage of IEEE 802.11n technology and is backward compatible with any IEEE 802.11 b/g Wi-Fi certified device. The ZyXEL AMG1202-T10B also supports multiple SSIDs with individual security and scheduling settings that facilitates different service levels for service providers.
1 (One) x RJ-11 ADSL port
4 (Four) x RJ-45 Ethernet port
Standard-based WPS for easy and secure WLAN establishment
Supports multiple SSIDs
Robust SPI Firewall protection
Remote provisioning and management through TR-069
Parental control scheduling by different interface and MAC address
ROM-D feature for distributor/operator easy customisation
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
Robust SPI Firewall Security
The SPI Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), Denial of Service (DoS) and Distributed DoS (DDoS) features, the ZyXEL AMG1202-T10B provides the first-line defence against hackers, network intruders and other harmful threats.
Quality of Service (QoS) support
The ZyXEL AMG1202-T10B comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users.
TR-069 Remote Management
With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "plug-and-play"experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
  • 802.11n technology for extreme performance and coverage
    The ZyXEL AMG1202-T10B featuring 802.11n technology provides the ultimate solution for speed and coverage. With data rate of up to 150 Mbps, the AMG1202-T10B provides stable and reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11 b/g Wi-Fi certified device.
  • Wi-Fi Protection Setup (WPS)
  • Robust SPI Firewall security
    The SPI Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), Denial of Service (DoS) and Distributed DoS (DDoS) features, the AMG1202-T10B provides the first-line defense against hackers, network intruders and other harmful threats.
  • Quality of Service (QoS) support
    The AMG1202-T10B comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users.
  • TR-069 remote management
    With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "Plug-and-Play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
Zyxel AMG1202-T10B - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, IPSec, PPPoE
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, HTTPS, CLI, TR-069
NAT support, VPN support, IGMP snooping, DoS attack prevention, packet filtering, ALG support, dynamic DNS server, manageable, IPv6 support, VPN passthrough, URL filtering, DDos attack prevention, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, port forwarding, reset button, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DHCP client, IGMP proxy
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
16.4 cm x 11.5 cm x 2.8 cm
201 g
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
PPTP, IPSec, PPPoE
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, RoHS, EN 60950-1
Status Indicators
Port status, power, WLAN, WAN, LAN
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex L
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
Aerial
Internal
Antenna Qty
1
Gain Level
3.5 dBi
External power adapter
United Kingdom
16.4 cm
11.5 cm
2.8 cm
201 g
45 °C
10 - 90% (non-condensing)
9KPP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
