Optimized for Smooth VoIP and Data Exchange
The ZyXEL GS-108B v2 8-Port Desktop Gigabit Ethernet Switch connects network devices and the home network at blazing Gigabit speed. The newly designed QoS ports guarantee smooth transfer for bandwidth-intensive applications such as VoIP and data communications.
Compact, sturdy switch with alternative wall-mount design
The GS-108B v2 fits any environment. Regardless of desktop or wall-mount installation, its sturdy, compact design provides more flexibility for wired home networks.
Fast, reliable wired connectivity
Without any manual configuration, the GS-108B v2 can boost data transfer speed for connected network devices such as IP phones, network storages, PCs and laptops to the network at blazing-fast Gigabit speed.
Optimized for smooth VoIP and data exchange
The GS-108B v2 has 3 QoS ports with an assigned high- and medium-priority mechanism to enhance the stability of VoIP and data exchange. Just connect network devices such as IP phones, PCs, laptops or network storages to the high-priority or medium-priority ports of your choice, you can then enjoy smooth VoIP communication and data transfer at the same time.
- Zyxel GS-108B - v2 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Switching fabric bandwidth: 16 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), 128KB packet buffer, Energy Efficient Ethernet, loop prevention
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V
- 16.4 cm x 9.8 cm x 2.6 cm
- 392 g
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 8K entries
- 9KB
- Routing Protocol
- IGMPv2, IGMP
- Status Indicators
- Power, link/activity
- 2 x 1000Base-T RJ-45 high priority , 2 x 1000Base-T RJ-45 medium priority , 4 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 5.5 Watt
- FCC Class B certified, C-Tick, BSMI
- Localisation
- United Kingdom
- 16.4 cm
- 9.8 cm
- 2.6 cm
- 392 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
