Zotac ZBox Intel IRIS Pro HD 5200 Core i7-4770R DDR3 BE
Quicklinx: 9BQ3WS00 Mfr#: ZBOX-EI750-BE
  • IEEE 802.11n
  • Core i7
  • Bluetooth 4.0
Zotac ZBOXEI750 Epic Gaming Series Barebone
ZBOX-EI750-BE - Zotac ZBOXEI750 Barebone, Intel Core i7 4770R 3.2Ghz, Intel Iris Pro 5200 GPU, USB 3, DisplayPort/DVI
Embrace mini-PC gaming with the 4th Gen Intel Core R-Series processor and Intel Iris Pro 5200 graphics packing ZBOX EI700 series. The new Intel Iris Pro 5200 Graphics processor enables the ZBOX EI700 series to deliver outstanding visuals and performance that's on par with discrete graphics cards and connect three native or up to four 1080p displays vid adaptors, or a si ngle 4 K display via DisplayPort or quad HDMI, with adapters, using intel collage display technology.
There's plenty of internal expansion capability in the ZBOX EI700 series with room to accommodate a 2.5 " SATA 3 SSD or HDD and mSATA 3 SSD. Intel Smart Response Technology enables the ZBOX EI700 series to combine the superior speed of an mSATA SSD with the higher storage capacity of standard 2.5" hard drives to create a single high-speed storage device that i ntelligently optimizes performance without user intervention for SSD-like performance with hard disk storage capacity. Features
  • Intel Clear Video HD technology
  • Intel InTru 3D technology
  • Intel Quick Sync Video technology
  • Intel Collage Display ready
  • Microsoft DirectX 11 compatible
  • 802.11ac WiFi & Bluetooth 4.0 technology
ZOTAC ZBOX E Series EI750 - mini PC - Core i7 4770R 3.2 GHz - 0 GB - no HDD
PC barebone - mini PC
Region: Europe
1 x Intel Core i7 (4th Gen) 4770R / 3.2 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Main Features
Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2, Intel 64 Technology
Cache Memory
6 MB L2 Cache
Cache Per Processor
6 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Card Reader
4 in 1
Graphics Controller
Intel Iris Pro Graphics 5200
Audio Output
Integrated
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
No operating system
Software Included
Drivers & Utilities
18.8 cm x 5.1 cm x 18.8 cm
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Region: Europe
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Chipset Type
Mobile Intel HM87 Express
Cache Memory
Installed Size
L2 Cache - 6 MB
Cache Per Processor
6 MB
RAM
Installed Size
0 GB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
SATA - integrated
Controller Interface Type
SATA 6Gb/s
Card Reader
4 in 1 card reader
Supported Flash Memory Cards
MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Audio Output
Integrated
DirectX
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin
1 x DVI , 2 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (1 front, 2 rear, 1 top) , 1 x microphone , 1 x headphones , 1 x HDMI (with adapter)
Vertical stand, wireless antenna, VESA mounting kit
HDMI-DVI adapter
Power adapter
Operating System / Software
OS Provided
No operating system
Software
Drivers & Utilities
18.8 cm
5.1 cm
18.8 cm
