Zotac ZBOXEI730 Epic Gaming Series Barebone
ZBOX-EI730-BE - Zotac ZBOXEI730 Barebone, Intel Core i5 4570R 2.7GHz, Intel Iris Pro 5200 GPU, USB 3, DisplayPort/DVI
Embrace mini-PC gaming with the 4th Gen Intel Core R-series processor and Intel Iris Pro 5200 graphics packing ZBOX EI700 series. The new Intel Iris Pro 5200 graphics processor enables the ZBOX EI700 series to deliver outstanding visuals and performance that's on par with descrete graphics cards and connect three native or up to ffour 1080p displays via adaptors, or a single 4K display via DisplayPort or quad HDMI, with adapters, using Intel Collage Display Technology.
There's plenty of internal expansion capability in the ZBOX EI700 series with room to accommodate a 2.5" SATA 3 SSD or HDD and mSATA 3 SSD. Intel Smart Response Technology enables the ZBOX EI700 series to combine the superior speed of an mSATA SSD with the higher storage capacity of standard 2.5" hard drives to create a single high-speed storage device that intelligently optimizes performance without user intervention for SSD-like performance with hard disk storage capacity. Features
- Intel Clear Video HD technology
- Intel InTru 3D technology
- Intel Quick Sync Video technology
- Intel Collage Display ready
- Microsoft DirectX 11 compatible
- 802.11ac WiFi & Bluetooth 4.0 technology
- ZOTAC ZBOX E Series EI730 - mini PC - Core i5 4570R 2.7 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Localisation
- Region: Europe
- Processor
- 1 x Intel Core i5 (4th Gen) 4570R / 2.7 GHz (, up to 3.2 GHz, (Quad-Core)
- Processor Main Features
- Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2, Intel 64 Technology
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Card Reader
- 4 in 1
- Graphics Controller
- Intel Iris Pro Graphics 5200
- Audio Output
- Integrated
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- No operating system
- Software Included
- Drivers & Utilities
- 18.8 cm x 5.1 cm x 18.8 cm
- Limited warranty - 2 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4570R
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
- Chipset Type
- Mobile Intel HM87 Express
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Card Reader
- 4 in 1 card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
Audio Output
- Integrated
- DirectX
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin
- 1 x DVI , 2 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (1 front, 2 rear, 1 top) , 1 x microphone , 1 x headphones , 1 x HDMI (with adapter)
- Included Accessories
- Vertical stand, wireless antenna, VESA mounting kit
- Cables Included
- HDMI-DVI adapter
- Power adapter
Operating System / Software
- OS Provided
- Software
- 18.8 cm
- 5.1 cm
- 18.8 cm
