Experience a gaming experience with the ZOTAC GeForce GTX 750 graphics card. Engineered from the ground up for maximum performance and efficiency, the ZOTAC GeForce GTX 750 graphics card delivers the performance gamers crave with best-in-class features that elevates PC gaming to the next level and a 60-percent greater energy-efficiency.
The ZOTAC GeForce GTX 750 graphics card supports the latest game-changing features including GeForce ShadowPlay to automatically capture the last 20-minutes of gaming to share your epic frags or live stream your gameplay with minimal performance impact. NVIDIA GeForce Experience support enables the ZOTAC GeForce GTX 750 graphics card to run the latest games with the best combination of performance and visual quality without additional tweaking.
- ZOTAC GeForce GTX 750 - graphics card - GF GTX 750 - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750
- Memory
- 1 GB GDDR5
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- CUDA Cores
- 512
- Effective Memory Clock
- 5 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 3
- Interfaces Details
- DVI , HDMI , VGA
- API Supported
- DirectX 11.2, OpenGL 4.4
- 14.884 cm x 11.115 cm
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- CUDA Cores
- 512
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- 3
- DVI , HDMI , VGA
- API Supported
- Nvidia CUDA technology, Nvidia PhysX-Ready, 3D Vision Surround, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready, HDCP
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 128-bit
- OS Required
- Microsoft Windows 7 / Windows 8
- Required Power Supply
- 400 W
- 55 Watt
- Included Accessories
- Low-profile bracket
- Software Included
- Drivers & Utilities
- RoHS
- 14.884 cm
- 11.115 cm
- Limited warranty - 2 years
