Zotac GeForce GTX 750 1GB PCI-Express 3.0 HDMI
Quicklinx: 9F4HWS00 Mfr#: ZT-70702-10M
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Experience a gaming experience with the ZOTAC GeForce GTX 750 graphics card. Engineered from the ground up for maximum performance and efficiency, the ZOTAC GeForce GTX 750 graphics card delivers the performance gamers crave with best-in-class features that elevates PC gaming to the next level and a 60-percent greater energy-efficiency.
The ZOTAC GeForce GTX 750 graphics card supports the latest game-changing features including GeForce ShadowPlay to automatically capture the last 20-minutes of gaming to share your epic frags or live stream your gameplay with minimal performance impact. NVIDIA GeForce Experience support enables the ZOTAC GeForce GTX 750 graphics card to run the latest games with the best combination of performance and visual quality without additional tweaking.
ZOTAC GeForce GTX 750 - graphics card - GF GTX 750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750
1 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1111 MHz
CUDA Cores
512
Effective Memory Clock
5 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Monitors Supported
3
Interfaces Details
DVI , HDMI , VGA
API Supported
DirectX 11.2, OpenGL 4.4
14.884 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1111 MHz
CUDA Cores
512
RAMDAC
400 MHz
Max Resolution
2560 x 1600
3
Interfaces Details
DVI , HDMI , VGA
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, 3D Vision Surround, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready, HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
128-bit
Microsoft Windows 7 / Windows 8
Required Power Supply
400 W
55 Watt
Low-profile bracket
Software Included
Drivers & Utilities
RoHS
14.884 cm
11.115 cm
