Get a taste of Microsoft DirectX 11 and hardware tessellation technologies with the ZOTAC GeForce GT 610 graphics card. The ZOTAC GeForce GT 610 delivers an outstanding visual computing experience with perfect high-definition video playback capabilities.
Hardware Blu-ray decoding capabilities enable flawless Blu-ray 3D playback while Dolby TrueHD and DTS-HD Master Audio bitstreaming enables bit-perfect audio output for the ultimate audio and visual experience with the ZOTAC GeForce GT 610 graphics card. HDMI 1.4 support ensures the ZOTAC GeForce GT 610 is compatible with the latest generation of 3DTV displays.
- ZOTAC GeForce GT 610 - graphics card - GF GT 610 - 1 GB
- Graphics card
- Bus Type
- PCI
- Graphics Engine
- NVIDIA GeForce GT 610
- Memory
- 1 GB DDR3
- Core Clock
- 810 MHz
- Stream Processors
- 48
- Effective Memory Clock
- 1.333 GHz
- Shader Clock
- 1620 MHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 2
- DVI-I (dual link) , HDMI , VGA
- API Supported
- DirectX 11, OpenGL 4.2
- 16.764 cm 6.891 cm
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Graphics card
- Bus Type
- PCI
- Graphics Engine
- Core Clock
- 810 MHz
- Stream Processors
- 48
- Shader Clock
- 1620 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- 2
- API Supported
- NVIDIA Unified Driver Architecture (UDA), integrated HD Audio controller, Nvidia PhysX-Ready, GPU Boost technology, Adaptive V-Sync, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.333 GHz
- Bus Width
- 64-bit
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Required Power Supply
- 300 W
- 29 Watt
- Included Accessories
- 2 low-profile brackets
- Software Included
- Drivers & Utilities
- Supported Windows 7 Features
- Windows Media Center
- RoHS
- 16.764 cm
- 6.891 cm
- Limited warranty - 2 years
