Embrace GPU computing with Microsoft Windows 7 and the ZOTAC GeForce 210 Synergy Edition graphics card. Compatible with DirectCompute and NVIDIA CUDA technologies, the ZOTAC GeForce 210 Synergy Edition delivers phenomenal GPU computing power for a great performance value.
The ZOTAC GeForce 210 Synergy Edition is ready for high-definition video playback as well with NVIDIA PureVideo HD video processing, HDMI 1.3a support with xvYCC, Deep Color technologies and 7.1-channel digital surround sound audio output for a premiere high-definition video playback experience.
- Chipset Manufacturer: NVIDIA
- GPU: GeForce 210
- Core clock: 520MHz
- Stream Processors: 16
- Shader Clock: 1040 MHz;
- Memory Clock: 1066 MHz
- Memory Size: 1 GB
- Memory Interface: 64-bit
- Memory Type: DDR3
- 2 Year Manufacturers Warranty (extended to 5 Years if card is registered with Zotac within 14 days of purchase)
- Model: ZT-20313-10L
- Interface: PCI Express 2.0 x16 (Compatible with 1.1)
- Chipset: Manufacturer Nvidia, GPU GeForce 210, Core clock 520MHz, Stream Processors 16, Shader Clock 1040 MHz
- Memory: Memory Clock 1066 MHz, Memory Size 1 GB, Memory Interface 64-bit, Memory Type DDR3
- 3D API: DirectX DirectX 10.1, OpenGL OpenGL 3.2
- Ports: DVI 1(DVI-I), HDMI 1, VGA 1
- General: Tuner None, RAMDAC 400 MHz, Max Resolution 2560 x 1600, RoHS Compliant Yes, SLI Supported No, Cooler Passive (without fan), Dual-Link DVI Supported Yes, Windows Certified for Windows 7 with DirectCompute support
- Warranty: 2 Year Manufacturers Warranty (extended to 5 Years if card is registered with Zotac within 14 days of purchase)
NVIDIA GeForce
NVIDIA GeForce series graphics processors are the epitome of graphics performance, and deliver phenomenal frame rates with stunning visuals in the latest 3D games and applications. -
NVIDIA PureVideo HD technology
NVIDIA PureVideo HD technology empowers ZOTAC GeForce-series graphics cards with HD playback capabilities for vivid visuals and hardware decoding of Blu-ray disk formats. -
ZOTAC Firestorm
ZOTAC Firestorm allows users to fine tune their graphics card to extract maximum performance from ZOTAC GeForce 8, 9 and GTX series graphics cards by enabling users to overclock GPU engine, memory and shader clock speeds and GPU fan-speed. -
PhysX by NVIDIA
NVIDIA GeForce GPUs with CUDA technology enable hyper-realistic GPU accelerated PhysX gaming effects such as explosions that cause dust and debris, amazing natural water and fluid effects, characters with life-like motion or cloth that drapes and tears naturally
- ZOTAC GeForce GT 210 - Synergy Edition - graphics card - GF 210 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce 210
- Memory
- 1 GB DDR3
- Core Clock
- 520 MHz
- Effective Memory Clock
- 1.066 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- DVI-I (dual link) , VGA , HDMI
- API Supported
- OpenGL 3.2, DirectCompute, DirectX 10.1
- 14.5 cm x 6.9 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 520 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- NVIDIA Unified Driver Architecture (UDA), integrated 7.1 channel HD Audio controller, fanless heatsink, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia Lumenex Engine, Nvidia GigaThread technology, Nvidia PhysX-Ready, Deep Color technology, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.066 GHz
- Bus Width
- 64-bit
- OS Required
- Microsoft Windows Vista / XP / 7
- Required Power Supply
- 300 W
- 18 Watt
- Included Accessories
- 2 low-profile brackets
- Software Included
- Drivers & Utilities, ZOTAC Boost, ZOTAC FireStorm
- Supported Windows 7 Features
- Windows Media Center
- RoHS
- 14.5 cm
- 6.9 cm
