All Zoostorm Small Form Factor Desktops are designed around the principles of productivity, longevity and low costs of ownership. These PCs are also designed to be space saving and configured to work with business.
All Zoostorm SFF systems feature Ethernet connection and if productivity, reliability and results matter to you, you can't do any better than a Zoostorm Small Form Factor desktop solution. It comes with No Operating Systems.
A durable keyboard and mouse are also provided with the package.
Specification
-Processor: Intel® Core™ i5-4440 Processor (6M Cache, up to 3.30 GHz)
-Operating System: None
-Hard Disk: 500GB SATA Hard Drive
-Memory: 6GB DDR3 1333Mhz
-DVDRW
-Graphics : Intel® HD graphics 4400
-Memory Slot: 2 x DIMM (1 free)
-Network Interface: 10/100/1000 LAN
-Dimensions: (D x W x H): 330mm x 90mm x 393 mm
-Box Dimensions: 417mm x 250mm x 475mm
-Boxed Weight: 11.5KG
-1 Year RTB Warranty
Internal Expansion
-1 x PCI-e x 16 slot (Free)
-2 x PCI-e x 1 slots (Free)
-4 x Sata ports (2 Free)
-1 set 5.1 channel Audio jacks (3 jacks)
-2 x PS/2 Keyboard/ Mouse ports
-6 x USB 2.0 ports
-1 x RJ45 LAN port
-1 x DVI-D port/ 1 x HDMI port
-1 x VGA port
