Designed to meet the challenges of harsh manufacturing environments, the Symbol LS3578-FZ features fuzzy logic technology which allows first pass reads of nearly any 1D bar code, even when the bar code is dirty or damaged.
Reliable and secure wireless data transmission between the scanner and host is guaranteed with integrated Bluetooth, while the 150 ft. (45 m) range allows operators to move freely without being restricted by a cord. A rugged, drop-resistant design and a sealed housing provide reliability with less accident-related equipment failure and downtime.
- Symbol LS3578-FZ - barcode scanner
- Barcode scanner - portable - Bluetooth - decoded
- Yellow, twilight black
- Minimum Bar Width
- 5 mil
- Scan Element Type
- Visible laser diode
- Scan Speed
- 36 scan / sec
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth
- Battery
- 1 x Lithium Ion
- 12.3 cm x 7.4 cm x 18.7 cm
- 414 g
- 3-year warranty
Barcode
- Interface Type
- Bluetooth
- Minimum Bar Width
- 5 mil
- Scan Element Type
- Light Source Wave Length
- 650 nm
- Scan Speed
- 36 scan / sec
- Skew (Degrees)
- 50
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 25%
- Decode Capability
- Code 93, Code 39, UCC/EAN-128, IATA, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, Discrete 2 of 5, Codabar, Code 128, Code 11, Interleaved 2 of 5, Code 128 Full ASCII, Code 39 Trioptic
- TTL Decoding
- Decoded
- Wireless
- OK Notification
- Beeper, LED indicator
- Bluetooth
- 1 x USB
- Cables Included
- 1 x USB cable - 2.1 m
- VCCI, EN 61000-3-2, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, Bluetooth Class 2, IEC 60601-1-2, IEC 60529 IP65, ICES-003 Class B, FCC Part 15 B, OET 65 C, MITI, RSS-102, EMC, RoHS, IEC 825-1, FCC CFR21 Part 1040, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, CSA C22.2 No. 60950-1-07, IEC 60825-1, EN 300 328, EN 301 489-1, EN 301 489-17
- Power Device
- Power adapter - external
- Battery
- 1 x Lithium Ion
- 12.3 cm
- 7.4 cm
- 18.7 cm
- 414 g
- Limited warranty - 3 years
- -20 °C
- 50 °C
- 5 - 95%
- Drop Specification
- 2 m to concrete
