- ZALMAN ZM600-GV - power supply - 600 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- 80 PLUS Certification
- 80 PLUS Bronze
- Input Voltage
- AC 115-230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- +3.3V - 20 A / 0.1 A , +5V - 17 A / 0.2 A , +12V - 46 A / 0.5 A , -12V - 0.3 A / 0 A , +5VSB - 2.5 A / 0 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties
- 15 cm x 14 cm x 8.6 cm
- ATX12V 2.3
- PSU Form Factor
- ATX
- Input Voltage
- AC 115-230 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50/60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- Efficiency
- 88%
- 80 PLUS Bronze
- Cable ties
- Cables Included
- Power cable - external
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, Two-Forward Switching Circuit Design
- UL, CB, FCC, WEEE, KC, ErP 2013
- 0 °C
- 35 °C
- 5 - 95%
- 15 cm
- 14 cm
- 8.6 cm
- Shipping Weight
- 2.05 kg
