Built-in circuits protects against voltage surges, current surges, power surges, low tension, short circuiting, and overheating. Smart fan control system optimizes thermal control while minimizing noise levels.
High quality components
High quality made in Japan 105°C solid capacitor guarantees stability at high temperatures, frequencies and currents. -
Active PFC
Built-in active PFC circuit provides high power factor and efficiency. -
Secondary protection IC
Built-in circuits protects against voltage surges, current surges, power surges, low tension, short circuiting, and overheating. -
Modular cable type
Neatly organized DC output modular cable help to increase air flow inside the case. -
Ultra quiet 139 mm for smart cooling
- ZALMAN ZM550-XG - power supply - 550 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- +3.3V - 22 A / 0.2 A , +5V - 18 A / 0.2 A , +12V - 45 A / 0.3 A , -12V - 0.3 A / 0 A , +5VSB - 2.5 A / 0 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 2 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 139 mm fan
- 15 cm x 18 cm x 8.6 cm
- ATX12V 2.3
- PSU Form Factor
- ATX
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- Efficiency
- 92%
- 80 PLUS Gold
- MTBF
- 100,000 hours
- Cooling System
- 139 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, cable management, short-circuit protection, CrossFireX ready
- UL, CB, FCC, KC
- 0 °C
- 40 °C
- 5 - 95%
- 15 cm
- 18 cm
- 8.6 cm
