Small and sleek, the Y-cam Cube offers exceptional video quality and audio representation whilst blending harmoniously into its surroundings, whether at home or in the office. Offering powerful, market-leading night vision and enhanced by automatic IR cut filter operation, it provides uncompromising color and picture quality, day or night.
Combining advanced H.264 technology, the Y-cam Cube uses minimal bandwidth and storage requirements. With smooth, real time video and audio streaming it can be viewed via any Internet-enabled computer or phone from anywhere in the world.
The Y-cam Cube is compatible with PC, Mac, web browsers and a multitude of recording possibilities, including an on-camera microSD slot. Equipped with intuitive motion detection, the camera can instantly store footage and send email alerts, providing ultimate control and the power to protect from wherever you are.
Video and audio
See and hear exactly what your Y-cam Cube does, from anywhere, with its in-built professional quality imagery and audio. With the highest quality CMOS lens and microphone you can experience outstanding quality video with full resolution at 30 fps. -
24/7 protection
The Y-cam Cube combines an IR cut filter and 28 instantly activating high powered infrared LED lights offering 24/7 security. This provide true day color representation and crisp night time images, even in pitch black, creating ultimate security through the day and night. -
Motion detection & alarms
Easy to configure motion Windows set through the camera user interface. The threshold and sensitivity of these motion Windows can be determined by the user, offering total control. The Y-cam Cube is able to send email notifications, alerts and snapshot to any dedicated email account. This will alert the user to any activity in real time, no matter where the recipient may be. -
H. 264 compression
The latest compression technology, H.264, allows for highly efficient network utilization and reduces the need to extensive storage solutions. This reduces costs and achieves higher quality for less power. -
Wi-Fi N
Utilizing the most advanced Wi-Fi technology, the Y-cam Cube is a connective camera to date. Housing Wi-Fi N compatibility users can now experience the widest and fastest connection speeds, insuring networks are optimized. -
MicroSD recording
Capture every moment directly on your camera with the Y-cam Cube. Have the ability to store up to 64GB of data directly on the camera with the built-in microSD memory card slot. It doesn't need 3rd party software, recording devices or an Internet connection, meaning it can work in more remote locations. -
Advanced compatibility
From NAS or NVR drives, to external hard disks, to home automation - Y-cam will integrate with the products you already own. Additionally, frequent firmware and software updates allow the Cube to grow at the same time as the rest of your system. -
Simple & secure
The camera compiles the latest encryptions including WEP, WPA and WPA2 for ultimate control and security. However the intuitive interface means you can implement the highest quality security with ease and efficiency. -
Wi-Fi protection setup
Instantly connect your camera to your home Wi-Fi network. With the built in WPS functionality you can connect you camera in seconds, making setup as easy as pushing a button.
- Y-cam Cube - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 6.5 cm x 3 cm x 6.5 cm
- 80 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 640 x 480
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/4" - 0.31 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/2.0
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 12 V
- Motion sensor, auto exposure control, e-mail alerts, microSD card slot, infrared cut filter, Wi-Fi Protected Setup (WPS), auto gain control, auto white balance
- Environmental Parameters (operating)
- -5 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 6.5 cm
- 3 cm
- 6.5 cm
- 80 g
- Localisation
- United Kingdom, United States, Europe
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MPEG-4, MJPEG, 3GPP, H.264
- Max Digital Video Resolution
- 640 x 480
- Infrared LEDs
- 30
- Infrared Distance
- 15 m
- Video Capture
- 640 x 480 @ 30 fps
- Still Image Capture Resolution
- 640 x 480, 320 x 240, 160 x 120
Image Sensor
- 0.31 MP CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 60
- Vertical Field of View (degree)
- 45
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, RTCP, PPPoE
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- Cables Included
- 1 x network cable - external
- White
- Power Requirements
- DC 12 V
- Power Device
- Power adapter - external 3.75 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Apple MacOS X 10.4, Microsoft Windows Vista / XP / 7, Windows 8
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium III - 1 GHz - RAM 256 MB , MacOS X 10.4 - PowerPC G4 - 800 MHz - RAM 128 MB
- -5 °C
- 45 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
