The Radeon R7 250 GPUs are packed with incredible features and unprecedented performance. These advanced graphics cards feature the award-winning GCN Architecture for spectacular performance and efficiency. Equipped with the latest technologies, they deliver enhanced performance to accelerate your game & multimedia applications - why settle for anything less?
The XFactor - see the XFX difference
Quality components, greater durability, pro components and dust-free fan. -
Maximize your gaming experience
Multi-monitor and stereoscopic 3D. -
Multi-monitor gaming
See more real-life peripheral vision around sides and see enemies you would have missed in single monitor gaming. -
4K resolutions
Super high resolution ready for tomorrow's applications and screens. -
Superb gaming graphics
Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products. -
6X tessellation
More triangles means more details to give you more realistic environments. -
Full destruction physics
Environment reacts to gameplay to give you realistic destructibility. -
Partially resident textures
Preprocessed resident textures to free up GPU resources and take advantage of mega texturing. -
Great performance
GCN Architecture allows to achieve higher utilization for improved performance and efficiency. -
Advanced performance optimization
Accelerate your games and professional applications. -
See the multi-monitor difference
Improve your productivity from everyday task to professional workstation applications.
- XFX Radeon R7 250 - graphics card - Radeon R7 250 - 2 GB
- Graphics card - low profile
- Graphics Engine
- AMD Radeon R7 250
- Memory
- 2 GB DDR3
- Core Clock
- 1000 MHz
- Boost Clock
- 1050 MHz
- Stream Processors
- 384
- Effective Memory Clock
- 1.6 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- HDMI: 4096 x 2160 / VGA: 2048 x 1536
- Max Monitors Supported
- 2
- DVI-D (Single-Link) , HDMI , VGA
- API Supported
- DirectCompute, OpenCL 1.2, OpenGL 4.3, DirectX 11.2
- 4.1 cm x 19 cm x 12.1 cm
- Graphics Engine
- AMD Radeon R7 250
- Core Clock
- 1000 MHz
- Boost Clock
- 1050 MHz
- Stream Processors
- 384
- Max Resolution
- 4096 x 2160
- 2
- API Supported
- Integrated 7.1 channel HD Audio controller, fanless heatsink, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Catalyst technology, AMD Hybrid Graphics Technology, Enhanced Quality Anti-Aliasing (EQAA), Adaptive Anti-Aliasing, AMD HD Media Accelerator, Graphics Core Next (GCN), AMD ZeroCore Power technology, Blu-Ray 3D Support, Double Precision Floating Point, AMD App Acceleration 2, Intelligent TDP management technology, XFX Multi-Display Technology, Partially Resident Textures (PRT), cutting-edge integrated display support, 128-bit floating point HDR rendering, Multi-Stream Transport, AMD Unified Video Decoder (UVD), Advanced Video Color Correction, Morphological Anti-Aliasing (MLAA2), HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.6 GHz
- Bus Width
- 128-bit
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
- Included Accessories
- PSU Cross Marketing Insert
- Software Included
- Drivers & Utilities, AMD Catalyst Control Center
- RoHS
- 4.1 cm
- 19 cm
- 12.1 cm
