XFX ProSeries exclusive SolidLink technology replaces wires - which cause wattage loss - with direct pin connections. The result is an extremely efficient high-power PSU. Also, with EasyRail technology, you get one single rail for maximum power and easy set-up.
80 Plus Gold certified
80 Plus Bronze certified means that this XFX PSU has up to 90% power efficiency at typical load. With XFX PSUs, you get nearly every watt you pay for. 80 Plus (trademarked 80 Plus) is voluntary certification program intended to promote efficient energy use in computer power supply units (PSUs). -
XFX exclusive SolidLink technology
New Double Sided PCB and SolidLink design drastically reduce the wires inside the PSU which improves efficiency. Other PSUs have numerous wired internal components, which generate heat, wasting energy and decreasing efficiency. -
XFX exclusive EasyRail Plus technology
Simplest and most powerful PSU design allowing you to handle your many devices without worry. No matter what combination of devices and components you have, PSUs have plenty of power to handle all your needs. -
XFX PSUs are Haswell ready
Among other improvements of Intel's latest Core Processors, power consumption in idle mode has been greatly reduced from around 6W to less than 1W. This might cause some older power supplies to shut the system off when the CPU enters idle mode, or prevent the system from waking up out of sleep mode. XFX Haswell Ready PSUs are designed to prevent this problem from occurring to ensure your system is always functioning properly. -
XFX exclusive total thermal system design
TTS features hybrid mode, which when activated, allows the PSU to operate silently until it reaches 25% load or 25°C. XFX fluid Dynamic Bearing Fan lower noise consistently over long periods of operation and lastly new digital IC extends fan life by adapting accurate detection and eliminating unnecessary fan rotations when turning on/off. -
AMD Crossfire and NVIDIA SLI ready
XFX PSUs are designed and tested to be compatible and optimized for multi GPU builds.
- XFX XTR Series P1-1250-BEFX - power supply - 1250 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.2/ EPS12V 2.91
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1250 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 104 A , -12V - 0.5 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 11 x 15 pin Serial ATA power , 8 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Black
- 15 cm x 17 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 100-240 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1250 Watt
- Output Current
- Efficiency
- 90%
- Power Factor (PF)
- 0.99
- 80 PLUS Gold
- Cables Included
- Power cable - external
- Cooling System
- 135 mm fan
- Overheat protection, solid capacitors, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, SolidLink, DC-DC technology, Intel 4th-gen CPU (Haswell) compatible, EasyRail Plus Technology, fully modular
- FCC Class B certified, UL, TUV, C-Tick, cUL, CB
- Limited warranty - 5 years
- 15 cm
- 17 cm
- 8.6 cm
- Shipping Width
- 32.3 cm
- Shipping Depth
- 21.1 cm
- Shipping Height
- 14.2 cm
- Shipping Weight
- 5 kg
