With the value-packed WorkCenter 6605 color multifunction printer, today's busy, small workteams can easily make important business communications stand out from the competition with exceptional color printing.
Print quality
A print resolution of up to 600 x 600 x 4 dpi makes your printed communications stand out and grab attention. Photo Mode makes your images and graphics look exceptional, producing deeper, richer colors for lifelike vibrancy. Unique Xerox EA Toner fuses at a much lower temperature, and reduces power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner. It's also oil-free, delivering brilliant, glossy output, even on ordinary or recycled paper. Pantone Color calibrated solid-color simulations and Xerox color correction technology ensure results that match your expectations. -
Productivity and reliability
A fast print speed of up to 36 ppm means your documents are always ready when you need them. The main 550-sheet paper tray holds a full ream of paper. An optional 2nd tray increases total capacity up to 1250 sheets for even longer periods of uninterrupted productivity. -
Ease-of-use
The innovative 4.3-inch touch screen features bright, colorful icons and intuitive navigation for optimal ease-of-use. Use the WorkCenter 6605 to scan your hard copy documents and get text-searchable digital files that can be automatically shared via email or network folder, or saved on the device or any USB memory device for true portability. The WorkCenter 6605 is simple to install on your office network, getting you up and running in minutes.
- Xerox WorkCentre 6605DN - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 80000 impressions
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Display
- 4.3"
- Original Size
- 140 x 140 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels
- Standard Media Capacity
- 700 sheets
- Max Media Capacity
- 1250 sheets
- Bypass Feeder Capacity
- 150 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network
- Power
- AC 230 V (50/60Hz)
- 43 cm x 52.8 cm x 56 cm
- 32.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 80000 impressions
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB 512 MB
- Max Supported Memory
- 1 GB 1 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, fit to page, Clone Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF, XPS, PCL 5
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
- Colour Management Features
- PANTONE Digital Color
Scanning
Fax Machine
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), junk fax barrier, LAN fax, poll receive
Document & Media Handling
- Min Original Size
- 140 x 140 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 50 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- 700 sheets
- 1250 sheets
- 150 sheets
- 250 sheets
- ADF - 50 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 550 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- SNMP, HTTPS, IPv6, Bonjour
- LDAP, Secure Print, SSL, IPsec, 802.1x, Secure Fax, IP filtering
- Operating System Support
- UNIX, Linux, MS Windows XP or later, Apple Mac OS X 10.5 or later
- Software Included
- Xerox CentreWare Web, Xerox CentreWare Internet Services, Xerox Email Alerts
- Voltage Required
- 560 Watt
- Power Consumption Standby
- 72 Watt
- Power Consumption Sleep
- 6 Watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 13 sec
- First Copy Out Time Colour
- 16 sec
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 43 cm
- 52.8 cm
- 56 cm
- 32.5 kg
- Sound Emission
- 29 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
Ink (9)
Xerox 6600 High Capacity Black Toner 8K | In Stock | £122.51 |
Xerox 6600 High Capacity Yellow Toner 6K | In Stock | £168.51 |
Xerox 6600 High Capacity Magenta Toner 6K | In Stock | £168.51 |
Xerox 6600 High Capacity Cyan Toner 6K | In Stock | £168.51 |
Xerox 6600 Black Standard Capacity Toner 3K | In Stock | £61.64 |
Xerox 6600 Magenta Standard Toner 2K | In Stock | £75.43 |
Xerox 6600 Standard Capacity Yellow Toner 2K | In Stock | £75.43 |
Xerox 6600 Standard Capacity Cyan Toner 2K | In Stock | £75.43 |
Xerox 6600 Imaging Drum Unit | In Stock | £230.59 |
Other bundles (2)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
Xerox Waste Toner Collector for Phaser 6600 | In Stock | £22.82 |
