Xerox WorkCentre 6505N Colour Laser Multifunction Printer
Quicklinx: 8J82WS00 Mfr#: 6505V_N
Your busy work-team needs a value-packed color device that gets the job done with the rare combination of outstanding print quality, unparalleled simplicity and day-in, day-out dependability. The WorkCentre 6505 color multifunction printer gives your important documents a powerful, colorful boost. A high print resolution makes your printed communications stand out and grab attention. Xerox exclusive toner uses particles engineered for uniform size and shape, producing superior image detail and line de?nition, and text that's sharp and clear. Pantone Color approved solid-color simulations and Xerox color correction technology ensure results that match your expectations.
Connect and go, thanks to built-in networking and seamless compatibility with mixed-user environments, including PC, Macintosh and Linux. With Xerox CentreWare IS, remote device administration is handled with ease right from your computer's browser. The device features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location. The value-packed WorkCentre 6505 multifunction printer will save on energy and supplies costs by combining the functions of multiple devices into one.
  • WorkCentre 6505
    The Xerox WorkCentreTM 6505 colour multifunction printer. Today's busy workteams need a value-packed colour device that handles all of your printing needs with that rare combination of outstanding print quality, unparalleled simplicity, and day-in, day-out dependability. Get total peace of mind with our one-year, on-site warranty.
  • Quick Facts
    •Colour: up to 23 ppm • Black: up to 23 ppm • Maximum paper size: 216 x 356 mm • Standard paper capacity: Tray 1: 250 sheets • Maximum paper capacity: 500 sheets • Automatic document feeder: 35 sheets • 533 MHz processor • 256 MB memory standard, 768 MB maximum • Windows (including Windows 7) and Mac compatible • Minimum dimensions (w x d x h): 430 x 544.2 x 584.4 mm • Power requirements: 240 V, 50/60 Hz • What comes in the box • Colour and black print cartridges (capacity: 1,000 pages each1) • Scan to PC Desktop CD (Nuance PaperPort, ImageRetriever, OmniPage) • Power cord • Fax cable • Software and documentation
  • Productivity Features
    •The value-packed WorkCentre 6505 colour multifunction printer means serious business for your workteam, providing real-world MFP capabilities and a host of built-in features • Superior performance gets your jobs out quickly, with colour and black-and-white print speeds up to 23 ppm • Powerful scanning capabilities include Scan to Email, Network Scanning, Direct Scan to Applications including Optical Character Recognition, and Scan to USB memory device • Standard copy features include ID Card Copy, N-up, auto fit, cloning, collate and more • Send faxes from the network using LAN Fax, or take advantage of full walkup fax features such as speed dial, remote receive and fax broadcast • A powerful 533 MHz processor and 256 MB standard memory handle your workteam's demanding workload - including multipage print jobs with graphics, photos and charts
  • Print Quality Features
    •A print resolution of up to 600 x 600 x 4 dpi delivers an amazing 16 shades of colour per pixel. That means a wider colour range for more expressive business graphics • Unique Xerox EA toner technology gives you crisp text and printed images with superior detail and clarity. It's the same high-quality toner used in our professional graphic-arts colour devices • True Adobe PostScript 3 means you can count on consistently precise print jobs with bright, true colours and superior graphics • PANTONE Colour approved solid-colour simulations and Xerox colour correction technology provide easy tools for precisely matching the colours of important business assets, such as company logos
  • Reliability and Ease-of-use Features
    •The intuitive LCD user interface makes it fast and easy to configure device settings and program jobs • A front-side USB port allows users to quickly print from or scan to any standard USB memory device • A 35-sheet automatic document feeder handles media sizes from 139.7 x 139.7 mm to 216 x 356 mm • The CentreWare IS internal web server makes it easy to handle device administration right from your computer's browser • Outstanding reliability is backed by Xerox with a one-year on-site warranty • Easy installation and pre-loaded toner cartridges make this printer virtually plug-and-play • Simple supplies replacement via convenient side door access • The Run Black feature lets you keep printing in black-and-white even if the printer runs out of colour toner
  • Environment-friendly Features
    •Print more, use less. Whether you choose manual two-sided printing, or upgrade to convenient automatic duplexing, you'll conserve paper for reduced costs and increased sustainability • With minimal packaging, our toner-only cartridges allow for 80% less waste than comparable colour devices using integrated print cartridges, and also let you easily store backup toner in a desk drawer • A small footprint allows for easy integration within your work space, whether on your desk or in a shared location • Extra-quiet operation to minimize impact on busy offices 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19798. Yield will vary based on image, area coverage and print mode.
Xerox WorkCentre 6505N - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Max Copying Speed
Up to 23 ppm (mono) / up to 23 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Fax Resolutions
400 x 400 dpi
Scanning
1200 x 1200 dpi
Original Size
140 x 140 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Optional (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
43 cm x 54.4 cm x 58.4 cm
28.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
Standard Memory
256 MB 256 MB
Max Supported Memory
768 MB 768 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Copying Features
Fit to page, ID Card Copy, Clone Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Image Enhancement Technology
4-bit depth colour technology
Automatic Duplexing
Optional
First Print Out Time B/W
12 sec
First Print Out Time Colour
12 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
400 x 400 dpi
Fax Machine Features
Broadcast Transmission
Delayed Transmission
Fax forwarding, e-mail function, colour faxing, LAN fax
Document & Media Handling
Min Original Size
140 x 140 mm
Max Original Size
Original Type
Sheets, books
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
250 sheets
Max Media Capacity
500 sheets
1 sheet
150 sheets
ADF - 35 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP
Security Protocols & Features
SSL, IPsec, 802.1x, Secure Fax
Operating System Support
MS Windows XP, MS Windows Server 2003, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008
Software Included
ScanSoft PaperPort, ScanSoft OmniPage, Nuance Image Retriever
AC 230 V (50/60Hz)
425 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
18.4 Watt
Warm-Up Time
31 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
20 sec
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
GOST, GS, NOM, FCC Part 15 B, EMC, R&TTE, UL 60950-1, CSA C22.2 No. 60950-1-07, Section 508
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
43 cm
54.4 cm
58.4 cm
28.4 kg
Sound Emission
22 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
10 - 85% (non-condensing)
