Xerox WorkCentre 6027V_NI Colour Laser Multifunction Printer
Quicklinx: B41MWS00 Mfr#: 6027V_NI
The compact WorkCentre 6027 Color Multifunction Printer excels in small office environments where high-impact color, speed, Wi-Fi connectivity and ease of use are priorities. With efficient print, copy, scan, fax and email functions on one device, you can get your work done quickly, without a second thought.
  • Automatically feed documents
    Save time copying and scanning multiple-page documents with the 15-sheet Automatic Document Feeder.
  • Speedy faxing
    The WorkCentre 6027 Multifunction Color LED Printer comes packed with the most common fax capabilities at a speed of 33.6 Kbps.
  • Accomplish more and spend less time waiting
    The WorkCentre 6027 Multifunction Color LED Printer features a print speed of 18 ppm in color and 18 ppm black-and-white and provides color prints in less than 13 seconds.
  • Plenty of power
    The powerful 525 MHz processor and generous amount of standard memory handle your daily workload with ease, including pages full of graphics, photos and charts.
  • Superior image quality
    The 1200 x 2400 dpi enhanced image quality delivered by the Hi-Q LED print engine provides high resolution color printing with precise image alignment and fantastic detail.
  • Color your way
    Last-minute color adjustments are a snap for both the expert and novice user with powerful, easy-to-use controls in the Xerox printer driver.
  • Color touchscreen
    The large, intuitive 109 mm color touchscreen user interface makes complicated tasks simple.
  • Convenient USB port
    The WorkCentre 6027 Multifunction Color LED Printer's front-side USB port allows you to print from, or scan to, any standard, portable USB memory device.
  • Streamline processes
    Powerful features simplify tasks for small offices, including the Paper Setup Navigator, taking the guesswork out of printing on custom paper sizes and types from plain office paper to envelopes and labels.
  • Print from anywhere
    Connect without the need for network cabling with standard built-in Wi-Fi, featuring one-touch setup. Simply press the WPS button on the printer, then the WPS button on your Wi-Fi enabled router, and then work and print from anywhere.
  • Connectivity simplified
    With Wi-Fi Direct, mobile phones, tablets, and laptop computers can make a secure connection directly to the multifunction printer even if you don't have an existing wireless network.
Xerox WorkCentre 6027V_NI - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi, 406 x 392 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
15 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, light-weight paper, glossy paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50/60Hz)
41 cm x 43.9 cm x 38.8 cm
16.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
LED - colour
30000 pages
1500 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page, ID Card Copy, collation copy, Edge Erase
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Colour Management Features
PANTONE Digital Color
Scanning
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
One-Touch Dialing
8 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, group dialling, auto reduction
Document & Media Handling
Max Original Size
Original Type
Sheets
15 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
150 sheets
100 sheets
ADF - 15 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Scanning: up to 14 ipm (A4) - B/W , Scanning: up to 9 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
SSL, WEP, WPA, WPA2, IPsec, WPA2-PSK, WPS, IP filtering, Wi-Fi Direct, TTLS
Operating System Support
Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit)
AC 230 V (50/60Hz)
330 Watt
Power Consumption Standby
45 Watt
Power Consumption Sleep
3.5 Watt
First Copy Out Time B/W
20 sec
First Copy Out Time Colour
30 sec
USB cable
Consumables Included
1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
EN55024, EN55022 Class B, EN 60950-1 Second Edition, Directive 2012/19/EU, Directive 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, IEC 60950-1:2005 Second Edition
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site
41 cm
43.9 cm
38.8 cm
16.9 kg
Shipping Width
56.7 cm
Shipping Depth
54.1 cm
Shipping Height
53.3 cm
Shipping Weight
19.9 kg
Sound Emission
21.9 dBA (idle) / 49.1 dBA (operating)
10 °C
32 °C
10 - 85%
