Xerox DocuMate 4700 A3 Flatbed Scanner
Quicklinx: 9M4TWS00 Mfr#: 100N02873
The DocuMate 4700 is an excellent flatbed scanner when directly connected to your PC. It also can become a flatbed option when connected to any Xerox DocuMate ADF scanner. Its USB hub changes the scanner to a combined configuration of distinct ADF and flatbed scanners that are addressable as one single scanner. So, if your needs suddenly change from the ADF-only scanner you have today, you can add a flatbed scanner and improve the investment you've already made in an ADF scanner. The ability to configure your DocuMate 4700 with an ADF scanner in series brings total flexibility to the entire DocuMate scanner product line.
The DocuMate 4700's powerful software, robust functionality and superior hardware specification delivers quality in every scan. Flatbed scanning offers the option to scan a wide variety of documents, such as books, magazines, plastic cards and fragile paper. Now there is no need to install multiple flatbed scanners across a network if the majority of users do not require this function on a frequent basis.
Xerox DocuMate 4700 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
297 mm x 432 mm
Supported Document Type
Plain paper
Duty Cycle
1000 scans per day
Microsoft Windows Vista / XP / 7 / 8
57.9 cm x 49.5 cm x 11.4 cm
6.99 kg
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Bulb / Light Source Type
LED
Duty Cycle
1000 scans per day
Scanner Features
Visioneer OneTouch Technology, Visioneer DriverPLUS Technology, Visioneer Acuity Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 432 mm
Plain paper
Supported Document Size Details
Flatbed - up to 297 x 432 mm
Interfaces Details
USB 2.0
1 x USB cable
External power adapter
Software Included
Drivers & Utilities, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Visioneer DriverPLUS, Nuance PDF Converter Professional
System Requirements Details
Pentium 4 RAM 2 GB - HD 500 MB
57.9 cm
49.5 cm
11.4 cm
6.99 kg
