The Xerox DocuMate 3115 has all the features you expect in a powerful desktop scanner such as a 20-page automatic document feeder (ADF), 30 images per minute duplex scanning speed, and Visioneer OneTouch with Kofax VRS technology. Then at the push of a button, the DocuMate 3115 ejects from its docking station to become a full function mobile scanner. When undocked, the DocuMate 3115 can be powered by a second USB cable instead of an AC adapter, providing a true mobile experience for users on the go.
Modern offices are no longer defined by traditional walls and desks, so when your work space is not contained within four walls, you need a scanner with flexibility. Whether scanning contracts, forms, receipts, photos, ID cards, handwritten notes or virtually any document of varying size or complexity, the DocuMate 3115 does its job so you can do yours. It is the perfect companion for anyone in the fields of healthcare, real estate, construction, financial services or insurance.
If you can't search your scanned documents by their content, you might as well be looking at paper again. The DocuMate 3115 can scan automatically to searchable PDF. The Xerox DocuMate 3115 integrates Kofax VRS image enhancement technology into the OneTouch scanning process.
Mobile and desktop flexibility in a compact scanner
The Xerox DocuMate 3115 has all the features you expect in a powerful desktop scanner such as a 20-page automatic document feeder (ADF), 30 images per minute duplex scanning speed, and Visioneer OneTouch with Kofax VRS technology. Then at the push of a button, the DocuMate 3115 ejects from its docking station to become a full function mobile scanner. When undocked, the DocuMate 3115 can be powered by a second USB cable instead of an AC adapter, providing a true mobile experience for users on the go. The front feed slot accepts documents from letter/legal/A4 size to photos, receipts and plastic ID cards. -
Flexibility to meet the needs of any job
Modern offices are no longer defined by traditional walls and desks, so when your work space is not contained within four walls, you need a scanner with flexibility. Whether scanning contracts, forms, receipts, photos, ID cards, handwritten notes or virtually any document of varying size or complexity, the DocuMate 3115 does its job so you can do yours. It is the perfect companion for anyone in the fields of healthcare, real estate, construction, financial services or insurance. Documents are most often captured where the user first encounters them. The DocuMate 3115 is well-equipped for use in a wide range of business applications, possessing strong qualities of both mobile and desktop scanners. -
Scanning in one touch
Powered by Visioneer OneTouch technology, the scanner allows users to scan to the "destination" of their choice by pressing a single button, eliminating multiple steps usually required to save scanned documents in popular file formats. Visioneer OneTouch allows you to scan documents to your choice of 6 preset yet completely user configurable destinations. This enables your documents to be scanned with the correct settings for resolution, color, cropping, file format and then delivered to virtually any application, folder or device - all at the touch of a button.
- Xerox DocuMate 3115 - sheetfed scanner - desktop - USB 2.0
- Sheetfed scanner - desktop
- Interface Type
- USB 2.0
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Size
- 216 mm x 356 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 20 sheets
- Duty Cycle
- 500 scans per day
- System Requirements
- Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Certified for Windows Vista
- 29.7 cm x 11.9 cm x 12.2 cm
- 1.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Duty Cycle
- 500 scans per day
- Scanner Speed Details
- 15 ppm - black & white - 200 dpi , 15 ppm - colour - 150 dpi , 30 ipm - duplex - black & white - 200 dpi , 30 ipm - duplex - colour - 150 dpi
- Scanner Features
- Visioneer OneTouch with Kofax VRS Technology
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Automatic
- 20 sheets
- USB 2.0 - Type B
- Included Accessories
- Docking station
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- ENERGY STAR Certified
- Software Included
- Presto! BizCard, Nuance PaperPort, Visioneer OneTouch with Kofax VRS Technology, Nuance OmniPage
- OS Required
- Additional Requirements
- DVD-ROM, USB port
- System Requirements Details
- Windows 2000/XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB , MacOS X 10.4 or later - PowerPC G5 - 1.6 GHz - RAM 512 MB - HD 350 MB
- 29.7 cm
- 11.9 cm
- 12.2 cm
- 1.8 kg
