WD Blue 500GB Mobile 7.0mm Hard Disk Drive - 5400RPM SATA 6Gb/s 2.5 Inch - WD5000LPVX
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: 8RH6WS00 Mfr#: WD5000LPVX
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features ensure low power consumption and long battery life.
  • Quiet
    In a notebook drive, silence is golden. WD's exclusive noise reducing technologies yield one of the quietest 2.5-inch hard drives on the market.
  • The original
    WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning hard drives.
  • Compatible
    The 7 mm 2.5-inch mobile drives is designed for thin and light mobile applications, and is also compatible with most standard 9.5 mm bays.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
WD Blue WD5000LPVX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
500 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
0.13 Watt (idle)
RoHS
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Sound Emission
17 dBA
