Secure your precious memories on My Book desktop storage. This USB 3.0 drive is optimized for the fastest possible data transfer rates and features complete protection for your files. WD SmartWare pro automatic backup software protects your precious memories, while Acronis true image WD edition helps ensure the security of all the information on your PC. Password protection with hardware encryption keeps your private stuff private.
Up to 3x faster transfer rates
My Book desktop storage is optimised for the fastest possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to access and save files up to 3x faster than with USB 2.0. -
Universal connectivity
With this drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well. -
Local and cloud backup
WD SmartWare pro automatic backup software lets you choose when and where you back up your files. -
System-level backup
Acronis true image WD edition is an integrated software suite that helps secure all the information on your PC. With it you can back up your files on a system level, including your operating system, securely delete confidential data, restore backed up data quickly and restore your system should your computer crash. It's the perfect complement to the file level backup of WD SmartWare pro. -
Secure your files
WD Security utility allows you to set password protection and hardware encryption for your drive to help keep your private stuff private.
- WD My Book WDBFJK0060HBK - hard drive - 6 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 6 TB
- Hardware Encryption
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Security lock slot (cable lock sold separately), password authentication, hardware encryption, automatic backup, NTFS formatted
- Power Source
- Included AC adapter
- Enclosure Colour
- Black
- 49 mm x 139.3 mm x 170.6 mm
- 1.06 kg
- Localisation
- Middle East, Africa, Europe
- 2-year warranty
- Capacity
- 6 TB
- Interface
- USB 3.0
- 49 mm
- 139.3 mm
- 170.6 mm
- 1.06 kg
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Software Included
- WD SmartWare Pro
- OS Required
- Apple MacOS X 10.6.5 or later, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable - external
- RoHS
- Enclosure Colour
- Black
- Localisation
- Package Type
- Retail
- Limited warranty - 2 years
- 5 °C
- 35 °C
