WD 4TB (2 x 2TB) My Book Thunderbolt Duo
Quicklinx: 94D3WS00 Mfr#: WDBUTV0040JSL-EESN
Finally, a drive can keep up with your creativity. Video editors and other digital media professionals can do more work in less time with the ground-breaking data transfer speed of the Thunderbolt ports on My Book Thunderbolt Duo drive. It offers the indisputably fast way to get information to and from your external drive.
My Book Thunderbolt Duo, dual-drive storage system featuring Thunderbolt technology, sets new standards for data transfer speeds and workflow flexibility in an affordable, high-capacity storage system.
  • Move data at unprecedented speeds
  • High-capacity storage
  • User-configurable RAID for speed or double-safe data protection
    You can select the RAID mode that's right for you. Choose RAID 0 (striping) for the performance you need when designing or editing graphic-intensive media files. When the drive is set to RAID 1 (mirroring) it provides double-safe data protection by automatically generating a duplicate copy of your data. Set the drive to JBOD (Just a Bunch Of Disks) to use as two individual drives and select between HFS+J or ExFAT per disk.
  • Daisy chain several drives together for even faster speed
    The intelligent Thunderbolt connector provides two channels of up to 10 Gb/s transfer rate in both directions. This means data can travel both ways without compromising bandwidth. Add to that the power of multiple drives processing data and you get amazing speed.
  • High-speed multi-tasking
    Bi-directional Thunderbolt technology delivers unmatched speed for multi-tasking while video editing, 3D rendering and completing other graphics-intensive projects.
WD My Book Thunderbolt Duo WDBUTV0040JSL - hard drive array
Hard drive array
Total Array Capacity
4 TB
Thunderbolt
2 (installed) / 2 (max)
Middle East, Africa, Europe
Storage Controller
RAID RAID RAID 0, 1, JBOD
Hard Drive
2 x 2 TB HDD
Apple MacOS X 10.6.8 or later
AC 120/230 V - 50/60 Hz
9.9 cm x 15.7 cm x 16.5 cm
2.15 kg
3-year warranty
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
4 TB
HDD Array External Interface
Thunderbolt
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 2 TB
Expansion Bays
2 (total) / 0 (free) x internal
2 x Thunderbolt
1 x Thunderbolt cable
Software Included
WD Drive Utilities
RoHS
External power adapter
9.9 cm
15.7 cm
16.5 cm
2.15 kg
Limited warranty - 3 years
5 °C
35 °C
