WD REĀ® (Nearline Class Enterprise Drives)
Fast, reliable and enterprise-ready. Ideal for: Servers, video surveillance, and other demanding write-intensive applications,
- Massive capacity
- High performance technology
- 24x7 reliability
- Dual actuator technology
- StableTracā¢ - The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking during read and write operations.
WD RE4 7200 RPM Enterprise SATA hard drives offer massive capacity loaded with performance and reliability features ideal for servers, video surveillance, and other demanding write-intensive applications. With a designed, manufactured and demonstrated MTBF of 1.2 million hours at 100% duty cycle in nominal enterprise conditions, 64 MB cache, and best-in-class vibration tolerance, these drives are the ultimate in Enterprise SATA storage. Backed by a 5-year limited warranty.
Industry's highest capacity nearline drive
WD RE SATA hard drives has high capacity to suit even the most demanding storage needs. -
Highest performance for business-critical applications
WD RE delivers 6 Gb/s transfer rates, sustained sequential data rates of up to 171 MB/s and high random I/O rates. -
Designed for quality and reliability
With a field-tested 1.2 million hour MTBF, this high performance drive delivers the highest level of reliability for 24 x 7 operation in up to 100% duty cycle applications. -
Dual processor
Twice the processing power to maximize performance. -
Vibration protection
Enhanced RAFF technology includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration in real time. The result is a significant performance improvement in high vibration environments over the previous generation of drives. -
A head positioning system with two actuators that improves positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy. -
StableTrac
The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking during read and write operations. -
Multi-axis shock sensor
Automatically detects the subtlest shock events and compensates to protect the data. -
RAID-specific, time-limited error recovery (TLER)
Prevents drive fallout caused by the extended hard drive error-recovery processes common to desktop drives. -
NoTouch ramp load technology
The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit. -
Thermal extended burn-in test
Each drive is put through extended burnin testing with thermal cycling to ensure reliable operation. -
Dynamic fly height technology
Each read-write head's fly height is adjusted in real time for optimum reliability.
- WD RE WD3000FYYZ - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T.
- 101.6 mm x 147 mm x 26.1 mm
- 750 g
- 5-year warranty
- Designed For
- My Cloud EX4
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Bytes per Sector
- 512
- 101.6 mm
- 147 mm
- 26.1 mm
- 750 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 168 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,200,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 9.6 Watt (read) , 9.5 Watt (write) , 8.1 Watt (idle) , 11.9 Watt (active)
- RoHS, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
- Sound Emission
- 31 dBA
- Designed For
- WD My Cloud EX4
