WD 3TB My Passport Ultra 2.5" USB 3.0 External Portable Hard Drive - Berry
Quicklinx: BGVFWS00 Mfr#: WDBBKD0030BBY-EESN
My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption.
  • Sleek design with high capacity
    This drive is sleek and fast with plenty of capacity for your important digital content.
  • Local and cloud backup
    WD SmartWare Pro automatic backup software lets you choose when and where you back up your files.
  • Ultra-fast transfer rates
    When connected to a USB 3.0 port, My Passport Ultra lets you access and save files with blazing speed. Reduce transfer time by up to 3 times when compared to USB 2.0 transfer rates.
  • USB 3.0 and USB 2.0 compatibility
    With this single drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
  • Secure your files
    WD Security allows you to set password protection and hardware encryption for your drive to help protect your files from unauthorized use or access.
  • USB-powered
    Powered directly from the USB port on your PC. No separate power supply is needed.
WD My Passport Ultra WDBBKD0030BBY - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, automatic backup, NTFS formatted, cloud backup
Power Source
USB bus
Enclosure Colour
Wild berry
81.57 mm x 110.07 mm x 20.96 mm
230 g
Middle East, Africa, Europe
3-year warranty
3 TB
Hardware Encryption
256-bit AES
USB 3.0
81.57 mm
110.07 mm
20.96 mm
230 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities
Apple MacOS X, Microsoft Windows Vista / 7 / 8
1 x USB cable - external
RoHS
Enclosure Colour
Wild berry
Package Type
Retail
Limited warranty - 3 years
5 °C
35 °C
