WD's Se hard drive provides an ideal solution for scale-out data centers, delivering a cost-effective combination of performance, reliability, and workload capability while maintaining the hardiness of a true enterprise-class design. This WD data center storage device is designed from the ground up to deliver optimal performance and maximum data integrity.
Time-tested, multi-generation platform
Built on a time-tested, multi-generation platform, with over 28 million terabytes of enterprise-class storage shipped, WD understands reliable high-quality products are the backbone of your data center investment. -
Designed for quality and reliability
All drives undergo at least 5 million hours of functional testing, and over 20 million hours of additional testing under actual workloads in actual server and storage systems. -
RAFF rotational vibration cancellation technology
Enhanced RAFF technology includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration in real time. The result is a significant performance improvement in high vibration environments over the previous generation of drives. -
Dual actuator technology
A head positioning system with two actuators that improves positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy. -
StableTrac
The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking during read and write operations. -
Multi-axis shock sensor
Multi-axis shock sensor automatically detects the subtlest shock events and compensates to protect the data. -
RAID-specific, time-limited error recovery (TLER)
RAID-specific, time-limited error recovery prevents drive fallout caused by the extended hard drive error-recovery processes common to desktop drives. -
NoTouch ramp load technology
The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit. -
Thermal extended burn-in test
Each drive is put through extended burn-in testing with thermal cycling to ensure reliable operation. -
Dynamic fly height technology
Each read-write head's fly height is adjusted in real time for optimum reliability.
- WD SE WD3000F9YZ - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T.
- 101.6 mm x 147 mm x 26.1 mm
- 750 g
- 5-year warranty
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 750 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 168 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,000,000 hours
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 9.5 Watt (read) , 9.5 Watt (write) , 8.1 Watt (idle)
- RoHS, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance
- 65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
- Sound Emission
- 31 dBA
