Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
For loading games or large files
The WD Black drive features a dual-core processor that offers twice the processing capability as a standard single-core processor to maximize drive performance. -
High-speed data transfer
WD's Dynamic Cache Technology improves performance in real time to allocate and optimize cache between reads and writes. -
Increased reliability
Helps reduce system-induced vibrations from other components, optimizing performance and reliability.
- WD Black Performance Hard Drive WD3200BEKX - hard drive - 320 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 320 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 16 MB
- Spindle Speed
- 7200 rpm
- NoTouch ramp load technology, dual processor, S.M.A.R.T.
- 69.85 mm x 100.2 mm x 9.5 mm
- 106 g
- 5-year warranty
- Capacity
- 320 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Buffer Size
- 16 MB
- 69.85 mm
- 100.2 mm
- 9.5 mm
- 106 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 115 MBps
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H
- Power Consumption
- 1.75 Watt (read) , 1.75 Watt (write) , 0.8 Watt (idle) , 0.2 Watt (standby) , 0.2 Watt (sleep)
- RoHS
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Shock Tolerance
- 350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
- Sound Emission
- 22 dBA
